1.920 visninger
Ny cykel {{forumTopicSubject}}
Hvad siger i til denne cykel?
Er det pengene værd eller kunne jeg finde noget bedre til samme pris?
http://www.bmw.dk/dk/da/owners/lifestyle/bmw_m_bike_2012.html
Man kan se hvilke komponenter der er på hvis man går ind i pdf filen og lidt længere nede på siden..
sep 2012
Følger: 1 Cykler: 1 Emner: 2 Svar: 8
Frame: Full carbon with BMW M logo
Fork: Full carbon
Handlebar: Syntace Racelite 31.8 7075, Black; handlebar
widths: 52–56 420 mm, 58–60 440 mm
Stem: Syntace F119 Force with shim, Black; stem
lengths: 52 90 mm, 54–56 100 mm,
58–60 110 mm, incl. BMW logo
Crank set: Shimano Ultegra FC-6750 50/34 teeth; crank arm
lengths: 52–56 172.5 mm, 58–60 175 mm
Brakes: Shimano Ultegra BR-6700
Wheel set: Specially made for BMW, 32-hole, with single
eyelets, Red
Tyres: Conti Grand Prix 4000, 28" x 1.00", ERTRO 25-622
Shift system: Shimano Ultegra, 20-speed derailleur system
Rear derailleur: Shimano Ultegra RD-6700
Front derailleur: Shimano Ultegra FD-6700, 34.9mm
Shifter / brake lever: Shimano ST-6700
Cassette: Shimano CS-6700, 11–28 teeth, 10-speed
Chain: Shimano CN-6600
Saddle: fi’zi:k Tundra 2 MG Red/Black
Seatpost: Kalloy SP-248
Pedals: Wellgo R120
Additional
equipment: Carbon drinks bottle holder
BMW M Bike Carbon Racer. There’s lightweight, and then there’s the BMW M Bike. With an
overall weight of just 7.4 kg, the BMW M Bike translates the BMW M lightweight design philosophy
into the world of two wheels. Its unmistakable frame design with an anthracite-coloured carbon
finish and the BMW M logo on the top tube are also reminiscent of the BMW M vehicles. Other
clues can be found in the rims, grip tape and saddle inlay in hallmark BMW M red. The fi’zi:k
Tundra 2 saddle ensures superior ride comfort even on longer rides. The Shimano Ultegra brake/shift
levers enable quick gearshifts even under full load, and the range of gear ratios makes this bike
just as suitable for rides on level ground as for demanding ascents. There is no doubt the
BMW M Bike is all about classic BMW M virtues – the most uncompromising combination of
performance and exclusive design.
Weight: 7.4 kg. Carbon frame.
Colour: Carbon
Frame size:
52 cm (height up to 170 cm)
54 cm (height 165–175 cm)
56 cm (height 170–180 cm)
58 cm (height 175–185 cm)
60 cm (height 180–190 cm)
80 91 2 211 849
80 91 2 211 850
80 91 2 211 851
80 91 2 211 852
80 91 2 211 853
Ny cykel
