  • Skift af tag 4.500 kr.
  • Opsætning af rullegardin, plisségardin, hattehylde og spejl 800 kr.
  • At smitte gaskomfuret til genbrug. Tager den ned fra 5. sal. 500 kr.
Kommentarer på:  Rock shox recon VS rock shox reba
  • #1   11. jan 2015 recon er tungere. Det er vidst den primære forskel.
  • #2   11. jan 2015 Ja okay.. Det betyder nok ikke alverden for mig.
  • #3   11. jan 2015 Specifications for Recon Silver TK
    Travel 80/100/120mm (120mm travel requires 15mm Maxle and tapered steerer only)
    Wheels 26", 29"
    Weight Solo Air 26": 2069g , Solo Air 29": 2186g , Coil: 2228g, * Weight based on 265mm 1-1/8" steerer, 9mm QR lower leg, Solo Air
    Damping TurnKey lockout
    Available Springs Solo Air / Coil
    Adjustments External rebound and TurnKey lockout, Spring: Air pressure via single Schrader valve, Solo Air / Spring via Preload, Coil, Coil optional spring rates: Extra Light (S1), Light (S), Firm (F), Extra Firm (F1)
    Steerer Options 1-1/8" aluminum (-145g), XL (320mm) 1-1/8" steel, XL (320mm) 1-1/8" aluminum, 1.5" to 1-1/8" tapered aluminum (-105g), 1.5" aluminum (-128g)
    Crown Forged 6061 T-6 Hollow Aluminum
    Upper Tubes 32mm, 4130 tapered wall steel, Satin Nickel
    Lowers Magnesium, Post Disc Mount
    Options Remote, Travel, Spring, Steerer, Color, PushLoc Remote, Lower Leg Option: Boss or disc specific. 15 x 100mm Maxle (+134g), 20 x 110mm Maxle (+168g), disc only
    Recommended Rear Shock Monarch R
    Maximum Rotor Size 210mm
    Color Options Black, White, Diffusion Black
    Remotes PushLoc Remote
    Other Upgrade: Over XC 32: 4130 tapered wall upper tubes,Maxle
    Specifications for Reba RL
    Travel 80/100/120mm
    Wheels 26", 27.5", 29"
    Weight 26": 1586g, 27.5": 1622g , 29": 1664g
    Damping 29": 1664g
    Adjustments External rebound, lockout, low speed compression to lock with internal floodgate,
    Steerer Options 1-1/8” Aluminum, Tapered Aluminum
    Crown Forged Hollow AL66 TV Aluminum
    Upper Tubes Aluminum 32mm, Fast Black
    Lowers Magnesium, 9mm QR or 15x100 Maxle Lite
    Maximum Rotor Size 200mm
    Remotes PushLoc Sprint
    Other Weight based on 265mm tapered steerer, 9mm QR lower leg, Solo Air
    Retail Availability August 2014
  • #4   11. jan 2015 Gon g--> jeg får intet ud af at læse det der.. Har skam selv googlet lidt frem og tilbage.. Jeg søger er direkte svar på forskellen..
    Dem jeg har googlet har begge haft mellem 100-120 mm vandring til 1/8" og med 9mm QR, luft affjedring i det ene ben og olie i det andet.. Recon'en har motion control.
  • Maller
    Maller Tilmeldt:
    aug 2013
    Følgere: 2 Emner: 8 Svar: 190
    #5   12. jan 2015 Reba er en bedre gaffel end recon, så hvis prisen er den samme så nap en Reba, det er en fin gaffel smiley
  • #6   12. jan 2015 Der er under 1000,- til forskel fra ny af
  • #7   12. jan 2015 Har fået tilbudt en recon brugt, til meget billig mønt.. Og ka pt ikke finde nogle brugte reba'er tilsalg der passer på.
  • #9   12. jan 2015 De passer ikke.. Har også købt en gaffel nu.
