2.192 visninger | Oprettet:
Gode Råd Opgradering Specialized Allez Comp C2 - model 2012 {{forumTopicSubject}}
Hejsa
tænker at opgradere min Specialized Allez Comp C2
Tænker at gearsæt/crank er fint og overvejer hjul og dæk - hvad mener i nogle gode råd..???
budget ca 4000 kr
herunder er info på cykel.
The frame is what Specialized call E5 aluminium whereas the rest of the Allez range are made from A1 aluminium. However, that doesn't mean much because Specialized don't make public what actually goes into those alloys.
The fork has an alloy steerer and crown and carbon blades.
HEADSET 1-1/8" upper and 1-1/2" lower Cr-Mo cartridge bearings integrated, w/ headset, 20mm cone spacer, w/ 20mm of spacers
STEM Specialized EliteSet, 3D forged alloy, 12-degree, 4-position adjustable, 4-bolt, 31.8mm clamp
HANDLEBARS New Specialized Tarmac Comp, alloy
TAPE Specialized S-Wrap, w/ gel
FRONT BRAKE Shimano 105
REAR BRAKE Shimano 105
FRONT DERAILLEUR Shimano 105
REAR DERAILLEUR Shimano 105
SHIFT LEVERS Shimano 105 STI, 10-speed
CASSETTE Shimano 105, 10-speed, 11-28t
CHAIN New Shimano Tiagra 10-speed
CRANKSET Shimano 105 compact
CHAINRINGS 50/34
BOTTOM BRACKET OS integrated, sealed bearings
PEDALS Nylon flat test ride, loose ball, w/ reflectors
FRONT WHEEL DT Axis 2.0
REAR WHEEL DT Axis 2.0
FRONT TYRE Specialized Espoir Sport w/ double BlackBelt, 60 TPI, wire bead, 700x23c
REAR TYRE Specialized Espoir Sport w/ double BlackBelt, 60 TPI, wire bead, 700x23c
INNER TUBES Lightweight, presta
SADDLE Body Geometry Riva Road
SEATPOST New Specialized Sport, alloy, 27.2mm
SEAT BINDER Alloy, 31.8mm
  • Opsætning tv 900 kr.
  • Skift af pærer på WW UP 600 kr.
  • Vandforsyning til opvaskemaskine 1.500 kr.
  • Opsætning af udendørs lamper og sensor 800 kr.
Kommentarer på:  Gode Råd Opgradering Specialized Allez Comp C2 - model 2012
  • #1   11. sep 2013 foresten er det Mavick cpx 22 hjul og Elite dæk
  • #2   12. sep 2013 Hjul vil hel klart give den største forskel, da det er roterende vægt. Du kommer ikke langt for 4k, når det kommer til gearet, men du kan dog overveje et specialized eller et BB30 kranksæt - så får du en større alu-aksel i stedet for en tynd stålaksel, og du sparer de adaptere væk, der sidder på den smiley
